Tunerpro .ads & .xdf question; DA2 & DA3
Car: '87 Corvette Convertible
Engine: 421 CID, Superram, LPE219, AFR 195s
Transmission: Built A4
Axle/Gears: D44 w/ 3.07s
I'm using V4 to help with a friend's '93 Corvette (auto trans), which XDF and ADS should I be using? I've noticed the DA2 xdf is limited compared to the DA3, but I can't find a DA3 ads & I get a mismatch.
I'm confused............
Re: Tunerpro .ads & .xdf question; DA2 & DA3
DA2.xdf is for 1992 LT1 engine
DA3.xdf is for 1993 LT1 engine
DA2.ads is for data on both engines.
Those files can be found here:
http://www.gearhead-efi.com/Fuel-Inj...mation-DA2-DA3
Good news, thanks a lot! The mismatch between the DA3xdf and DA2ads was confusing me.
