Wideband datalogger vs Autoprom/TunerPro
First off, a huge thank you to the ThirdGen creators and all of the contributors. You've been an immense help in my learning of DFI tuning. I've just started tuning and realize I need a wideband setup to get the most out of my mods. I'm tuning a 91 K5 350 w/7747 ecu, dart heads, cam, bored TBI & intake, Thorley headers w/Gibson 3", 21 PSI FP.
My question is about wideband data logging. How beneficial is it to use a stand alone hi-speed data logger with sensor inputs, like the Zt-2, vs. using TunerPro via one of the Autoprom analog inputs? Can I ultimately get the same results using slow 7747 ALDL/wideband data in TunerPro, or will a hi-speed data logger allow more accurate/finer tuning?
Opinions/lessons learned/expert input is greatly appreciated. THANKS!
Re: Wideband datalogger vs Autoprom/TunerPro
If you have the AutoProm already then use it. It's much easier to have your wideband data in same log then a differant log. I use AutoProm with my wideband this way on a 1227747 and others.
Is the data faster from other software? Probably, I don't know, but you still can't tune faster data if the ECM only goes so fast anyway? Haveing 2 logs is still a pain compared to one.
Here's another choice for wide band O2 sensor and controller which is known to work great. I've never used or seen the one you listed...
http://www.dynamicefi.com/TT-1.php
HTH!
HTH!
I've looked at the TT-1 and if I go the Autoprom route it will probably be the one I purchase. Do you know of any posts that describe how to set up Tunerpro for the Autoprom/wideband input for the 7747 data stream?
I've seen that the data sample rate of some wideband data loggers is as high as 80 times/sec. I agree that using 2 different logs would be more difficult, but would that much data lead to a more dialed in tune? Or for my K5 350 will it even make much of a difference? Probably not, but I've never done this so I don't know.
Thanks for the info.
1 Post
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
It's likely that I would have bailed on the7747, and it's 160baud ALDL rate.
However,
RBobs daughter board has high-speed comm. to go along with the other top-notch features.
http://www.dynamicefi.com/EBL_Flash.php
However,
http://www.gearhead-efi.com/Fuel-Inj...Information-42
EagleMark, thanks for the link to your files. I'll check them out this weekend and see if I can figure out the ADX changes.
Six_Shooter, I haven't seen the SLC_DIY. I'll take a look and compare to the others.
xch3no2, if I had known what I know now I probably would have changed ECUs...
No changes needed in those files! Already have AutoProm channel 1,2,3 in it! Could use any of them for any wideband wired into AutoProm
Car: 1978 Camaro
Engine: 385 Dual TBI, '7427
Transmission: 4L80E
Axle/Gears: 4.10, Posi
Or the other option is to upgrade your ECM to a PCM ('7427) and slip the WBO2 into the ALDL datastream. It works pretty sweet, and is about 6 times the sample rate as 160baud.
I decided to go with the Innovate MTX-L AFR gauge/controller. I should have it installed within the next week or so. I might have AutoProm/Tunerpro questions for you EagleMark.
efiguy
09-27-2015 01:30 PM
