Looking for 8746 IAT Patch
Old 08-30-2011, 12:33 PM
Grommet's Avatar
I've seen references to an expanded Inector constant vs. IAT table (factory table starts at 03A6) for the 8746, anyone know where I can find this?
Also, with the IAT table I'm assuming that number greater than '1' increases fuel at a given temperature and vice versa - correct?
Thanks!
Old 09-04-2011, 03:30 PM
HenryW's Avatar
Re: Looking for 8746 IAT Patch
I would also like this info - Anyone?
Old 02-22-2012, 12:42 PM
EagleMark's Avatar
I've done a lot of searching and can't find it although the XDF fro JPrevost is available with extended temp range for IAT. But a warning that without the patch it will look uneven, and a stock bin looks uneven...
Although I don't need the patch it could be useful to others?
I'd like to incorporate them into IAT on a P4 16197427 that can enable MAT, but MAT numbers would be from CPI engine way off from IAT. The only starting point I can find for IAT would be from a MPFI like my LT1 but intake manifold temps on MPFI dry manifold would be quite different then TBI wet manifold.
So the extended numbers from $61 being IAT and TBI would be a great starting point!
Does anyone have this patch done and table from XDF with results?
BlueIroc-Z
06-09-2019 03:22 AM
86White_T/A305
09-21-2015 05:28 PM
BWilcox
09-20-2015 12:19 PM
86White_T/A305
08-17-2015 12:16 AM
88irocz28
10-20-2000 05:29 PM
Quick Reply: Looking for 8746 IAT Patch
