my SAUJP thread- need to figure this MAT/IAT issue out. help!
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '86 Grand National
Engine: LZ9????
Transmission: 2004R
*EDIT* just going to contain one thread instead of opening a new one everytime i have a question.
yep did a search but didnt find the answer i was looking for. as some of you know im running the 7730 in my ferd. over the weekend i installed a furd racing E303 cam. .498/.498 220* at .050 and 110 lsa brand new never used for 40 bucks.
http://www.summitracing.com/parts/FMS-M-6250-E303/
initial start and warm up it runs beautiful, a little rich but tuneable. as soon as the coolant temps hits 68*C it starts to surge uncontrollably, i expected that. i tried open loop at first and then closed loop to try to get it to stabilize while i tried to tune it. it pulls ~62 kpa at 900 rpms. ive adjusted the blm ranges to get it to somewhat idle in cell 4. it wont stabilize at 800 rpms and now DFCO wont activate. still learning about what each cell does but it seems to stabilize better in cell 5? a quick rev and pushing in the clutch will almost stall, or just stall out. WBO2 shows 11 to 12:1 afr most of the time. im just curious why it idles and acts so nice up until 68* C and then feels like someone flipped the fubar idle switch. thanks!
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
Re: another surging idle thread
To stabilize my idle I had to make sure the areas around my "ideal idle point" at 900rpm and 55-60 Kpa didn't have areas around it with too much change from one spot to the next, or too much "slope on the hills" of my tables. It would make it surge and fall off as it went from high to low points. Biggest change was from flattening the spark and fuel table. It didn't need much change in fuel from 800-1000rpm and 45-60Kpa.
I also keep spark to about 22* in the same areas, again little change as to not make it rev and fall off.
Also had to cut IAC steps in half in terms of max steps, so it wouldn't bypass so much air past the throttle blades (58mm) I'm down to about 40 now. Generally much more stable.
Dave
edit 09/18/11 you might want to shift your BLM cell entries for MAP and RPM slightly so that you are idling in cell five all the time. my own engine is also happier idling at 900 rpm than 800.
Dave
Engine: LZ9????
Transmission: 2004R
Re: my SAUJP thread. question for RBOB
i think i may have this closer to being figured out. today ive raised my idle up to 900 from 800. i had a slight surge before the cam was installed at 800. ive had little problems with it idling, after DFCO sometimes it stalls and some low rpm surging/stumbling while cruising. i bought the car with a underdrive kit installed and the voltage starts to drop off at 850 rpm. coincidentally thats when the surging is the worst. so my injector offsets are in need of adjustment. i have the Ford bosch III 19#ers. someday, when i have more money, ill go up to a larger size. for now im stuck with these. RBob, in this thread i looked up, post #3 you said that the table only adds to PW 3.9 and less. i would like to know if i can adjust the offset to get these to "act" like a larger injector because the cam has made the engine come alive but these have trouble keeping up. iirc ive read somewhere that you can do this, or maybe not idk. im running 55# of fuel pressure and maxxed my VE tables at 4000 rpm and up, the PE v. rpm table is all the way up into the 30's. my datalog shows the PW being 13.3ms at 4750 rpms. probably need a bigger set lol. also, the table you attached in post #5, should i use those values since im using that injector? thanks!!
https://www.thirdgen.org/forums/diy-...gn-iii-pw.html
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Wouldn't it be better (and easier) to go back to a std size pulley?
Trying to ride the slope of voltage change is not going to make things easy on you.
Throttle follower and other IAC settings with manual can be tricky to get right.
A few others have had good results but I do not have any table data to give you on that.
Engine: LZ9????
Transmission: 2004R
Earlier this year I tuned a '71 Cutlass, that the owner just installed a larger cam in (Olds engine as well). What would happen, was that the engine would literally flood itself, when trying to idle. It was trying to idle at around 65 to 68 KPA, but wouldn't do this for long. The owner, to get the cam broken in, installed a resistor inline with the MAP sensor, to bring the load artificially down to around 45ish KPA. It idled like a dream here.
So to get this to happen without the resistor, I pulled fuel from the 1000 RPM (and lower) and 70 KPA area, down to the the 30 KPA area to force the engine to idle down after start. It worked great and idles almost like stock, with just slight surging, that I think is due to more to cam profile than tuning at this point. I had to raise idle from 600 to 675 or so as well. He has the benefit in this case of having a heavy torque converter attached to help act like a flyweight, but I'm sure a similar strategy could be used with a manual.
I would go back to a stock crank pulley for now, and then once this is tuned then try the under drive pulley.
At idle, the alternator is probably not spinning quick enough to create a charge, so doing anything with the regulator will just be for not. I have my Datsun set to idle at 900 RPM, because the crank pulley is so small (about 5" diameter), anything lower than 900 RPM, I get literally no charge. Even at 900 it's barely charging. This is the stock pulley too. :/
Car: check
Engine: check
Transmission: check
IIRC, they are for the type I injectors, not the III's.
RBob.
Engine: LZ9????
Transmission: 2004R
Re: my SAUJP thread. runs better
zerod out the low pw offset table and copied the values for the batt offset table. runs alot better, didnt have a chance to drive it more due to tranny replacement. buttoned up today and will drive it to work tonight. reset the base timing and it surged a little bit but none to serious. thanks everyone!
@sixshooter, ive pulled some fuel out from the idle area and down. but it still idles at 12.5:1 so i have a little bit more to do. actually, i have to pull more out of the whole range now except at higher rpms lol.
Engine: LZ9????
Transmission: 2004R
Re: my SAUJP thread. need MAT eq for ADX
anyone know the equation for the IAT/MAT in the ADX? everytime i tune the temp is different and im finding myself tuning in circles. usually i tune before work and its fairly warm and when i come home its 20-30* cooler and everything is lean. my MAT is still stuck at 18.5 and barely gets upto 19*C. brand new MAT, tried 2 so far. theres no equation in the ADX for the MAT either so i think that might be it.
Car: check
Engine: check
Transmission: check
RBob.
Engine: LZ9????
Transmission: 2004R
also, more tuning this afternoon. still wants to lean out above 4800, i lift shortly after i see the WBO2 AFRs going north of 13.5. inj PW is 20.48ms @4900 rpms, the calculator im using is telling me im at 83% DC, need new injectors lol. both the PE tables are maxxed out so im just going to baby it until i get new injectors.
Engine: LZ9????
Transmission: 2004R
hmmm well ok then lol. the MAT tables seem to be off enough for the engine to run lean at cold temps and rich in warmer air. not sure how to adjust those values without knowing what air temps the ecm is seeing. maybe a good old thermometer hung from my rearview mirror would do the trick lol
To set the ADX item to use a lookup table, you need to go into the ADX editor, open the item you want to edit, go to the conversion tab, click on "Send converted data to lookup table", then select the lookup table to use in the drop down menu just below that.
The Equation should be "X" as well.
Engine: LZ9????
Transmission: 2004R
Engine: LZ9????
Transmission: 2004R
lookup table seems correct, and the equation is set to X. going to test the connections and resistance next. thanks!
The eqution should only be "X" if using a lookup table... Yes ???
Or have you had imports that don't just have "X" ?
BTW, the table I made is in degrees F, not C because I hate the metric system
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Jp
Adjusting the idle deadbands may cure that surge.
https://www.thirdgen.org/forums/diy-...jp-v4-iac.html
Engine: LZ9????
Transmission: 2004R
Take a look at this thread. Some good info at the end that may help.
![doh](https://www.thirdgen.org/forums/images/smilies/doh.gif)
Engine: LZ9????
Transmission: 2004R
Engine: LZ9????
Transmission: 2004R
Re: my SAUJP thread, siemens 24.6# injectors offset question
forgot that i had some larger injectors laying around. they are siemens 53030262 rated at 24.6# at 39psi. found in mid 90's dodge magnum v8s. they look like single hole disc type injectors, so my question is, should i retain the same offsets as the ford bosch III? changing the intake gaskets due to a small leak and im thinking of using these. should have it running today....
Engine: LZ9????
Transmission: 2004R
Re: my SAUJP thread, displaying fuel pressure thru TPV5
what is everyone using as a fuel pressure sending unit for displaying fuel pressure in the datalogs? id feel better seeing if my pressure is dropping off at WOT. thanks!
1 Post
Car: '74 Firebird, '84 vette
Engine: 454 twin turbo, 350 HSR
Transmission: 4L80E, 700R4
Axle/Gears: 9", Dana36
I've not used mine yet, but I have a ford fuel pressure sending unit taken from some little ford car (may have been a focus not sure). The sender is a small unit that mounts to the fuel rail and has a 3 wire connection.
My initial thought was to use an oil pressure sender, but then I read (on this forum) that they may not be compatible with fuel.
Engine: LZ9????
Transmission: 2004R
1 Post
Its right on the fuel rail. Held on by two bolts.
I tried to find mine last night to take a picture, but I've misplaced it for now. I looked on rockauto.com and ford focus's from 2000 to about 2003 had a pressure "regulator" that bolts on the same as the one I have and has an electrical connector, but I dont recall mine having a diaphram like the one in the rockauto pics. I think the one I have is a bit more of a cube shape. I'll look again today and if I find it I'll post an image.
Attached is an image from rockauto.com of a 2000 focus regulator.
Car: check
Engine: check
Transmission: check
The other transducers that some use are Autometer replacement units. They come in 15, 30 and 100 psi. Can get them at places such as Jegs and Summit. Pricey at about $100 USD but easy to get, hook up and use.
RBob.
RBob.
1 Post
OK I still cant find my fuel pressure sender, but I did identify it. They come on a lot of fords 1999+ They are called an FRP sensor (fuel rail pressure). And also FRPT (fuel rail pressure and temperature) sensors. They come in 2 basic versions, a 4 wire and a 3 wire. The 4 wire includes a fuel temp sensor also. They have a nipple for a vacuum hose so I assume the pressure reading is relative to manifold pressure.
Attached are some images I've acquired from my browsing tonight.
1 Post
Also here is a site where somebody is making an microcontroller based electronic fuel pressure regulator for a motorcycle application using these bosch sensors, gives part numbers.
These should be a total no-brainer to use. They work just like a MAP or TPS sensor.
http://www.madhu.com/content/Main/FuelPumpController
I bought one of these. Good to 150 psi so I won't have to worry about it blowing out (hopefully)
http://prosportgauges.com/Premium-oi...-sender-1.aspx
I need to wire it up and connect to an air line to get the pressure Vs. Volts table built.
I'm assuming its linear output but I'd rather test it to see before installing it.
Engine: LZ9????
Transmission: 2004R
Re: my SAUJP thread, cold startup routine, surging after startup for about 1 min.
thanks for the replies for the fuel pressure sensor/sender!
JP, will that oil pressure sender work for fuel pressure?
ive been trying to solve an after startup condition, with no good results. it cranks and starts right up, but for about a minute after initial startup it surges. it also is rich during this time. after it settles in it idles pretty well. so which tables or constants can be adjusted for after startup? thanks!
"This can be used for either a Premium Series Oil Pressure or Premium Series Fuel Pressure gauge"
so I figured it will be OK with fuel.
For the rich after start you should see in your logs how the commanded AFR tapers off from really rich to 14.7 after startup.
There are some tables that adjust how much and how fast the removal of startup fuel is done.
441 and 44F have two tables that may give the adjustment you need. (use F7 to sort the XDF to find them)
I don't remember which direction each of these adjustments go so just make a change and see how it reacts. Then try the other table.
You may also just want to lower the VE table in the idle area to reduce the fuel there and see if that helps too.
Engine: LZ9????
Transmission: 2004R
i have me VE table dialed in for the idle its just the startup. same surge whether its hot or cold. do you think i should also add in some spark too? im thinking yes since this is a more aggressive cam and ive lost a little static compression down low. it would be under startup spark, correct? thanks JP!
I was thinking a little SA too but figured you tried that already.
If its at idle only then you would want to use the Closed Throttle SA table.
If its during warmup (before you are at the threshold temp) the main SA table at 100 KPA is used.
Do a quick check to see if the 100 KPA in the main table is what you have in the closed throttle table.
If the surge starts when it changes to the closed throttle table, that may be your answer.
Engine: LZ9????
Transmission: 2004R
it has a hunting idle and what part of the 100kpa table should i be looking at in relation to rpm?
The RPM that you idle at.
The main table 100 Kpa column is used prior to switching over to the Closed throttle table when warmed up.
The values you have in the two tables should be close to each other to avoid too much change when the transition occurs.
Engine: LZ9????
Transmission: 2004R
also, since ive migrated to texas, ive noticed that i had to re-adjust the VE table due to a really lean tune. so ive tweaked the MAT tables to help keep the tune consistant with the temperature change. its pretty close now but unfortunatley i have to guess since the MAT temp displayed is still stuck on 18.5-19.5*C. i know now that the IAT works since ive adjust the the MAT tables and the fueling changed. would there be a difference between values for the original MAT and newer IAT version lookup tables? im stumped at this point.
The way I would approach it is to set all values in the temp compensation table to the current running temp "value".
Then make all changes to the VE as you need to get pretty good fueling.
Once it is the best you can get it, start tweaking the temp table in the "temp of the day" cell to bring fueling back into line for that day.
If the temp changes enough to do additional cells then take advantage of the time to do it. Adjust adjacent cells to the new value so it stays reletivly consistent to where you have already made an adjustment.
#42
Engine: LZ9????
Transmission: 2004R
Re: my SAUJP thread- cool startup surge with DATALOG
did some searching and came across this thread;
https://www.thirdgen.org/forums/diy-...e-misfire.html
i adjusted the suggested tables as suggested but no difference. it seems like within the intial start up the ecm is overcompensating to control the idle but after that first minute it settles right in. when its warm or at operating temp it only surges for 10-15 seconds. im thinking that since the bin was designed to operate an auto tranny with a heavy torque converter, and i have a T5 with a far lighter clutch, that is the problem. i just dont know which to adjust to slow the overcompensation down. i have the AXXD for all the IAC functions, where else can i copy these values? thanks!
#44
Car: 91 corvette
Engine: 383SR
Dave
Dave
#45
Engine: LZ9????
Transmission: 2004R
Try adjusting the minimum TPS for AE higher. (Address 52E )
At idle you are bouncing on and off AE MAP.
Not sure what you have it set at now but take it up to 2-3% TPS setting.
Could be the extra fuel dumping in is causing it.
SA is also bouncing allot for this range, Do you have the RPM error tables for advance and retard lowered in the small RPM cells?
Might help.
Might help.
#47
Looking at the log some more made me think...
Is the fast movement of the IAC causing the AE MAP?
At zero TPS, AE shouldn't be enabled ???
Keep tweaking the IAC gains (not sure which one) will reduce the swing and possibly allow it to stabilize.
I still don't see why it just smoothed out all of a sudden. Something happens right there but I don't know what.
#48
Engine: LZ9????
Transmission: 2004R
edit* just checked the min tps for AE and its at 1.2%, the AXXD bin i have has it at 3.9%, copied and will try that
#49
Engine: LZ9????
Transmission: 2004R
i was just thinking, the IAC movement if fast enough is creating the AE MAP, if i can filter this value depending on coolant temp i think it may help? same with IAC movement depending on coolant temp?
#50
Engine: LZ9????
Transmission: 2004R
alright, just got back from a light cruise with another question. does the ecm mainly control idle by fueling and timing, without IAC, until rpm error reaches a certain point? more specifically, when the engine is first started, whether it be at lower temps or operating temps. reason i ask is ive reset the timing error tables to the AXXD bin values and the lower rpm error was 4.92 on the advance table and on the timing retard table some of the upper values were up at 9.XX*. started it up and no more surge. granted the startup temp was 130*F but earlier today before i reset those tables it still surged but not as long. am i making sense? ill report tomorrow after i start it for the first time.
now if i can only figure this annoying IAT temp sh*t. is there a way to display the raw values in the ADX?
