4L80E shift Harness and TP defintions $0E
#51
Car: Revcon Motorhome ECM:16197427 BJKW
Engine: 502 HT W/MPFI, Thorleys, Magnaflows
Transmission: 4L80E
Axle/Gears: 3.53 + Transfercase 1.11
Re: 4L80E shift Harness and TP defintions $0E
Update:
The after market trans controller did not resolve the issue. At first I thought it was working fine, but after about 50 miles of freeway driving, it started getting very flaky. The speed readout on the controller would climb up to about 50 mph or so, and then as I sped up more, it would start counting back down, so when I was doing 70, it read 40 mph. Of course then it kept switching between 3rd and 4th. I nursed it to the nearest exit. Found a Radio Shack, bought some switches, and wired up a manual shift box. I also hooked up the TC command again and drove 450 miles to home.
So, finally got underneath it to try to figure out why this has been so flakey. I assumed that maybe the speed sensor was weak, so I was going to swap front and rear sensors. Just for grins, I stuck my finger in the rear hole, and to my dismay, there is no reluctor ring. There is another gear right next to where the reluctor ring goes. The sensor was reading the other gear, but because it is a long way away, the pulse is very weak and erratic. OK, so this is BIG UGLY. To fix it, will require a complete trans tear down. It was all I could do to get the trans into the bottom of the vehicle, I just can't imagine doing it again. What is most frustrating is that I specifically asked the shop that built the trans to make sure to install the rear reluctor ring. They did not do it. I will be calling the shop tomorrow morning, we will see how that goes.
#53
Engine: X
Transmission: MT1
IIRC old (73-up) body style 1-ton, eg 91-93? R/V 3500 chassis. Might be worth seeing if those xfer case parts could go into your v-drive and save the output shaft R&R.
I'd wonder what else trans shop left out since they can't open an ATSG manual for 2 minutes or listen to the customer.
#54
Transmission: 4L80E
The ring is inside the trans, not inside the tail housing.
I have thought through what could be done with the chain case. Really, there is no space for anything other than the chain and bearings. There are setups that mount to the drive shaft, but the chain case is is not 1:1, so the ECM will not like the wrong ratio. That is already proven by the fact that it is already reading the other gear with less teeth. It is able to read the weak signal, but won't go into lock up and shifts hard, because it assumes there is slip between the input and output.
#55
Engine: X
Transmission: MT1
If you can find a 40ppr driveshaft/pinion mounted sensor just change the gear ratios in the calibration. Or run the PCM in 4wd and program in your xfer case ratio.
Plenty of people running 4L80E's with aftermarket low-gear sets, that's how they keep the PCM happy.
AmpleUnicorn88
Interior Parts Wanted
16
11-29-2015 05:45 PM
Billy Decker
09-04-2015 03:46 PM
