Bosch 3 #42 Green Giant injectors.
Old 02-18-2011, 03:15 PM
GTA
GTA's Avatar
Car: 1992 GTA
Engine: running
Transmission: working
Axle/Gears: both
Hi all,
I am asking is any one here running these #42 injectors from South Bay??
I was just wondering how hard they are to tune? I am installing a EBL P4 ECM next week and am planning on SC this engine next fall, ( reason for the big injectors ). Can the #42's be tuned to run well NA with out me pulling out my hair?? I am really excited about the EBL's VE learn capibilities, any way if any one with big injectors could respond that would be great, oh btw i am currently running FMS #24 in her right now so this is one heck of a big step up...GTA
Old 02-18-2011, 03:53 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: Bosch 3 #42 Green Giant injectors.
Why so big what you running
Old 02-18-2011, 04:16 PM
GTA
GTA's Avatar
Car: 1992 GTA
Engine: running
Axle/Gears: both
1,
I am planning on a SC, And NOT using the suplied FMU, I want to add all the Aditional fuel that boost will require via the injectors alone...that is why I picked the #42's as they will be plenty, GTA..
Old 02-19-2011, 11:32 AM
liquidh8's Avatar
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
I don't see why not, guys run 60 pph on 3.8 GN engines all the time, with a stock ECM and a chip. I too plan on running the EBL, and I will be upgrading from my 30pph, to 42pph when I it is available for my engine.
Old 02-20-2011, 07:41 AM
TGO - 10 Year Member
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
I'm running 42lb Bosch 3's from FIC. All I did was change the FI constant and mess with the Inj PW vs. battery voltage a little. Car runs fine.
Old 03-06-2011, 07:49 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
They aren't bad. I have the injector data for those and they tune in fairly well. It's easier to run them clean on an engine like the 3.8L since it is a sequential injection. Batch fire systems are less friendly with big injectors, but you should be fine with the 42's at stock fuel pressure. Good call on not running the FMU.
Old 01-29-2012, 07:32 AM
91 Droptop's Avatar
Engine: 355 Super Charged
Transmission: B&M Streetfighter
Axle/Gears: 4th gen 342
Sorry to resurect this post but I am getting ready to order these and I have a question
I am running a 355 with a Paxton SC, vortech aluminum heads and a HSR, I have a adj FP regulator, everything I read is I should go bigger? I believe 42 should do it, thoughts
Old 01-29-2012, 08:09 AM
pwdbychevy's Avatar
42lbers should be fine. You may want to upgrade the fuel pump if you haven't done so already.
Old 01-29-2012, 08:42 AM
91 Droptop's Avatar
Sorry, forgot to post that, I amm running a Walboro 255 now
Old 01-29-2012, 09:57 AM
pwdbychevy's Avatar
Thats what im using. How much power are you putting down to the wheels?
Old 01-29-2012, 12:18 PM
91 Droptop's Avatar
Not sure, thinking motor will be around 400 with out the super charger; will know better when I get it on a dyno
92-Formula
12-12-2015 10:34 PM
HoosierinWA
10-07-2015 10:15 AM
drumstixer
09-29-2015 03:02 PM
dusterbd
09-29-2015 08:40 AM
SS-EXPRESS
09-28-2015 09:14 AM
Quick Reply: Bosch 3 #42 Green Giant injectors.
