DIY prom database
Car: 1991 Z28
Engine: L31-R 350 w/ EBL P4
DIY prom database
One think I was wondering about when I was looking at the site is why there is no DIY prom database? When I go from my 305 to a 350 I'm going to need a new prom, and instead of programming my own why isn't there pre-built ones on the site?
It would be nice if there was a prom database where you could download pre-built proms for a car. The description would have all of the parts (cam, heads, intake, etc) that the prom was used to tune for. Make sure that all of the bins are of high quality and are good tunes. That way people could just buy the parts on the description for the certain prom, and then download the prom and burn it. It it would make the lives a lot easier for a lot of people that don't know how to code a motor.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: DIY prom database
This has always been a good reference for me.
Glad someone mirred it because the original site is gone now.
http://www.exatorq.com/ludis_obd1/
Cross referenced by ECM and year with different motor codes.
Car: check
Engine: check
Transmission: check
RBob.
Engine: X
Transmission: MT1
1/2 hour with stickies and search someone should have the shopping list of hardware to tune & burn their own eprom. Or realize they have no desire to learn how and take a different path.
It's not like we're back in the days of early 'Programming 101' TBI hacking where people could barely navigate the internets and "go read the archives" meant hours of combing thru text files and posting to mailing lists.
Car: 1991 Z28
I mean I wouldn't mind learning how to do it, I just honestly know nothing about engines. I know nothing about cams, valves, heads, etc. I would have to learn what everything means before I could even code.
1 Post
Car: 89 K3500 Fleetside
Engine: RAT *tbi* EBL
Transmission: TH400
Axle/Gears: 3.73-Dana 60
Welcome to the real world...life is (hopefully) a long & arduous journey, that leads to just rewards, (but don't get your hopes too high), not like a video game, or somebody might have told you, no cut & dry can be expected...
If you don't work for it, you should not have it...
Any of us living and enabled stand as mere (beaten & scarred) nats on the shoulders of giants, learn of their experience, the first example they set is hard work & study.
I was in your situation a few years ago. I presume you have a modded car and the stock prom no longer works for you. I dove into DIY prom tuning and hit a few bumps in road. I did not ask for a prom and not suggesting you are either. I asked a lot of questions first tuning year and found many members are pleased to help. Eventually it was learned that a member had a modded motor very similar to mine. That member volunteered to look at my DIY.bin and make a few changes. That helped me a lot in drivability. Consider adopting DIY and post a few Q's or many(be specific) and info on your set up. You will receive needed support. If you care not to get involved then there are vendors out there that can help.
Car: 1991 Z28
Well right now I have stock setup but in the summer I want to get a 350, which means a tune. I'm probably going to learn to code it myself, but it's not going to be too easy
Today is easy as compared to five or ten years ago. But it is still a steep learning curve. If you don't have a deep desire and a lot of time maybe you could just buy a chip from a vendor. Also talk to the vendor first and discuss the motor you want to build and they will guide you to a proven motor build and a tuned chip for it.
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
1 Post
Transmission: TH400
LOL
I quit smoking in October..
still a touch edgy, or some might say an azzz...
My tune continues to improve & the RAT silences all that question.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
How 'bout a DIY DIY-PROM database? Doesn't exist? Do it (or create it) yourself. When you add value to lives of community members (irrespective of what community we're talking about), there is often reward.
Transmission: T5WC
But if he and others who are widely regarded as leaders and contributors here agree? I would volunteer the time etc.. necessary to put something like this together as a pay back (or pay forward) for all the fun you guys started!
Or even a follow up to what Moates does and DIY-GM-EFI does...
3.8TransAM
09-27-2015 08:37 PM
