Shift light to control Nitrous trigger
Car: '89 Iroc Vert
Engine: 355 TPI
Transmission: T-5(for now)
Axle/Gears: 3.45 9 Bolt
I'm a little rusty with tuning, its been like 3 years since I've even opened tuner pro,
My car is an 89 Iroc, 355 TPI, running MAF, engine is built for nitrous,
anyway my plan is to force the shift light on and off at given RPMs, speed, and throttle position,
I'm going to test it first, triggering a light to make sure it only triggers at what I think its going too,
does anybody see why this wouldn't work?
I am worried about the 3 tables at the bottom, not sure what to put
1 Post
Car: 1989 Camaro
Engine: 383
Re: Shift light to control Nitrous trigger
Just my $.02 but I think you would
Shift light time on- ever how long it takes you to run 1/4 mile set it for that time or a
bit longer
Shift light on tale - all setting to 99% because you only want the nitrous on at wot
Shift light off table- all settings to 98% because you want it off as soon as you lift.
Make sure your TPS is reading to 99 or 100% at wot, otherwise you may need to lower the settings.
Not sure it will work but I see no reason why it wouldn't.
bit longer
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Others have done it that way. I used the egr outputs to control it and reprogrammed it to activate only in power enrichment.
db057
08-11-2015 10:11 PM
