Can someone help me identify this memcal?
Car: 89 FORMULA 350 / 1991 RX7
Engine: 5.7 L98 / LT1
Transmission: 700R4 / 6 speed manual
Axle/Gears: 3.42 posi / 4.11 posi
please see the attached pictures of the prom in question. Will this be a suitable chip to program for a stock 305 TPI build, with A 700r4? Any idea what year, engine, trans, car line it came from? thanks for the help.
68767 8936
DELCO ATNY 5672
014
045915
AC8923B
68767 8936
DELCO ATNY 5672
014
045915
AC8923B
Car: check
Engine: check
Transmission: check
Re: Can someone help me identify this memcal?
RBob.
thanks so much Rbob. Is there a referance table, or spread sheet for all the part numbers, chips used through the years? thanks
Engine: Many
Transmission: Quite a few
there used to be a free database that has since been taken down.....tunercat offers caldata for cheap if you need to know a bunch of 'em, but for looking up onsie-twosie, it's not that cost effective.
otherwise, just post up here and someone can look it up for you.
88SS6SPEED
11-11-2015 07:05 AM
