NVSRAM upload error?
Car: 88 IROC-Z Formerly Megasquirted
Engine: 355 HSR LT4 hotcam E85 13.5:1 comp.
Transmission: Upgraded T5 All metal stage3 clutch
Axle/Gears: zexel 3.42
Just installed my nvsram module. I'm using rt4tool.tcl it will download the bin correctly. Every time I try to upload an updated bin it hangs at 4% the computer goes into limp mode and the upload aborts with "ALDL error".
I read 1 other post with a similar error :
https://www.thirdgen.org/forums/diy-...-throttle.html
but according to this post despite the error his bin uploaded fine.
Any ideas or suggestions please.
Car: 91' Z28, 92' Z28
Engine: 383, L98 stock
Transmission: Built 700R4, Stock 700R4
Axle/Gears: 12 Bolt 3.73, 10 Bolt 3.23
Re: NVSRAM upload error?
Question: Did you assemble your own board? If so you need to clean the board with electric parts cleaner and a tooth brush very lightly to remove the extra flux left behind from soldering. If you didn't assemble then do it anyway. Craig from Moates.net told me to do that and I never had another issue. Because I was having the same issues you were having. Make sure the board is completely dry before installing.
I'll try that and post results. Thanks for the input.
school boy
10-22-2015 11:47 AM
