EPROM/Chip Switcher Suppliers
Car: 1986 Camaro T-Top
Engine: 2.8L V6 (MPFI)
Transmission: 5 Speed
Currently looking into acquiring a ready to go EPROM switcher and have only found info on building ones yourself or schematics. I know they are a bit dated with people using multiple bins on one chip, but any help would be appreciated.
(The one posted here [external link] is pretty much exactly what I need, but no supplier was listed; http://forums.rennlist.com/rennforum...-motronic.html)
1 Post
Car: 1985 IROC-Z28
Engine: LB9
Re: EPROM/Chip Switcher Suppliers
LOL, just use a SF512 and stack BINs on it... you can throw 4 16K or 2 32K BINs for multiple tunes, then just switch the highest address pin(s) from +5V to ground to change tunes... i made a DIY version for a whopping $.15, but it looks ghetto as hell. moates sells a nice setup, it's a bit tall though.
1 Post
Car: 1985 IROC-Z28
Engine: LB9
but it won't drop in a 28-pin DIP socket!
and i think you meant 16, not 26
i've got a pair myself, work great with the G3, but it would be nice if they could be integrated into a MEMCAL as easily as the 28-pin PROMs.
Yeah, this is a 28pin DIP, going into an a modded ECM with somewhat limited space lengthwise. Also going to be using stock chips, one for E85, one for E10/pure gas. Also, the ECM being used has 1MB images, not 32/16K.
Pino91Formula
03-17-2010 11:34 AM
