16196395 using DIS
Car: 1968 Chev Corvair
Engine: 164 CID HO
Transmission: 2 Sp Powerglide
Axle/Gears: 3.55
16196395 using DIS
I'm upgrading from a 7747 to a 6395. Because I use DIS instead of HEI, I had to program in Offset. The following Items had to be changed:
1) Initial timing (60*)
2) Maximum Spark Allowed (75*)
3) Maximum Retard allowed (-75*)
I was going to get ahead and started looking over tunerpro, the OD.XDF only has Initial timing.
What do I do about Max/Min spark allowed? and how?
thanks in Advance
Ted
thanks in Advance
Ted
Re: 16196395 using DIS
Go over to the Moates web sight and get the Advanced $0D v175.xdf, or just follow the links from hear:
http://www.fullsizechevy.com/showthr...D-Tuning-Files
(post #40)
Should help you out a lot.
(post #40)
vortech305
09-20-2001 07:47 PM
vortech305
08-19-2001 01:33 PM
vortech305
08-14-2001 03:48 PM
