Past data log sessions don't play in Tunerpro RT
Car: 1993 Caprice wagon "Shammoo"
Engine: tpi'd 406, with P4 ebl EBL 730 ECM
Transmission: custom "4L65" swap.
Axle/Gears: 3.42:1 with posi
first problem: I've noticed a wierd condition with my Tunerpro Rt concerning playback of previous sessions. As an example I recorded three short sessions yesterday trying to nail down the cause of my BLM's going lean around past 3600 rpm. I had two nice sessions in the laptop recorded and preceded to add a third on the way home.
Got home, I can only play the LAST session, and the other two only blip for a split second, and at the bottom of the screen it indicates zero data bites.. Then when I go back to play session three, it blips as well. The only way to replay the last session again is to closeout Tunerpro and reopen it, at which point only the last one plays again. I can't gaain access to the earlier sessions.
I even named some of the sessions to remember which is which and no names show up. Additionally If I do a general search in windows (not in tunerpro) for any session by just typing in "session", it can't find ANY thing with that name So is there a setting or procedure that I have missed that would allow me to "SAVE" and reply what I'm recording? And where is it in memory?
