Need help fellow members. Are these 2 PROMS the same?
I'm looking for a OEM PROM for an 87 TPI IROC-Z. I found these 2 PROMS and they look the same but are they significantly different?
This info is from Chevythunder.com
ABWN
8656
8161
Auto
3.27
Fed
F
ABWT
8674
8201
Auto
3.27
Fed
F
1 Post
Car: 86 Firebird SE
Engine: 2.8L
Re: Need help fellow members. Are these 2 PROMS the same?
I believe the ABWT is a revised ABWN code. They are obviously for an auto trans 350 car with 3:27 gears. If you have that gear ratio, either of those PROM's should work for you.
LiquidBlue
Wheels and Tires
32
12-10-2019 04:06 PM
