Moates Extreme ALDL Problem (USB Issue)
Car: C4 Vette
Engine: Gas Guzzler
Transmission: ZF-6 Manual
Axle/Gears: 3.75
Ok this has got me stumpped and I don't really know how to explain this but I'll try my best...
Here is my setup...
Tuner Pro V4 or V5 (Both the same)
LEAD A = ALDL
LEAD B = Ostrich II
When BOTH A & B are plugged into the Laptop everything seems to be OK but I do get a few ALDL errors.
With just lead A plugged in. I press connect in TP but it never does. (Windows see's the device no problem)
Here is where is gets screwy -
While its trying to connect if I simply "touch" lead B against my second USB socket it will connect. Please note I said touch... its not plugged it, its simply a metal on metal contact of the outter of the USB plug.
Any ideas?? I've only noticed this since trying to get Tunerpro V5 to work... I have probably always plugged them both in before opening tuner pro in the past.
Here is my setup...
LEAD A = ALDL
LEAD B = Ostrich II
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Moates Extreme ALDL Problem (USB Issue)
I would check that the ground pin in the ALDL is making good contact and is connecting to a good ground.
The Ostrich may be using additional grounding through the chip interface and allowing it to work.
Only thing that comes to mind why it would do that.
Car: C4 Vette
Engine: Gas Guzzler
Axle/Gears: 3.75
Great input - I wondered if something like that might be an issue, or even if it could effect it at all. Will check it ASAP
Car: C4 Vette
Engine: Gas Guzzler
Axle/Gears: 3.75
Ground to Pin A on the ALDL is good, and the contact looks ok between the socket and plug.
Back to the drawing board.
Street Lethal
04-30-2019 12:14 PM
9192camaro
16
02-03-2019 12:21 AM
