is there a 'log pulse width' patch for 1227747?
I want to check that I'm not running out of pulse width at higher RPMs. I saw in BMmonteSS's "free tune up" thread there's a patch for other bins to log PW instead of PROMID. Is there such a patch for the 7747?
Car: check
Engine: check
Transmission: check
Re: is there a 'log pulse width' patch for 1227747?
RBob.
I did searches for it, but I will look again in the tuning book sticky.
I'm sure it's one of those its-right-here-somewhere items.
FOUND IT. Thanks for the hint!
For the record (and end this thread) for the $42 bin for the 7747 (747, 1227747 :-), to put injector pulse width into the ALDL data's PROMID slot, follow this post from Rbob:
https://www.thirdgen.org/forums/post...16-post31.html
Thanks a million Rbob!
I know that the bin is 4K long ($1000) so addresses relative to the bin start/EPROM start are $0 - $fff.
So what is $DFE7 (etc) relative to? TunerPro RT's hex editor shows addresses relative to image start, 0.
Car: check
Engine: check
Transmission: check
Drop the D off the front of the address. The result will be the physical address within the EPROM. Once the EPROM is placed into the ECM the address is in the $D000 block of memory as accessed by the CPU. This is the virtual address of the location.
Note in the hac that all tables and calibration parameters start with $D, as in $D438.
Also note that when you start looking at other ECMs, this virtual address can be different. Both the $8000 block and $C000 block are common starting points for the EPROM.
RBob.
RBob.
OK, thanks, the patch is in and working. The reason for this is of course to make sure I'm not hitting 100% open (as per your excellent observation in the "free tune!!!!" thread).
