Tunercat Fail
Tunercat Fail
Hey guys just wondering if anyone has experienced this.I just downloaded the latest tunercat trial to see how well it works for tuning.After installing it on my pc win xp,the program loads..it never finds my emulator or burn1,it wont open Any bin file or allow me to choose a ecu file,the ecm column isnt even highlighted.
Is this because its the trial..I thought the trial was fully operational for 30 days?Hard to say I would invest in the program if I cant try it out first.Any suggestions or settings I need to make it work?
Car: check
Engine: check
Transmission: check
Re: Tunercat Fail
TunerCat uses a .tdf file. The file for maskid $42 ('7747 ECM) is included with the package. IIRC, until you load it the tuner won't do anything. Also, I think only the RT version will connect to an emulator and such.
RBob.
RBob.
Re: Tunercat Fail
Im using a 7730 ecm and running aujp $8d. How do I load a tdf type file if I cant open anything at all.Do I need to convert a xdf file into a tdf before I can use the program?
Re: Tunercat Fail
Car: check
Engine: check
Transmission: check
Re: Tunercat Fail
Click on the ECM selection on the menu bar. It should show a "ECM_42" entry. Click on that. Once the tdf is loaded you can then load a BIN file.
RBob.
RBob.
Re: Tunercat Fail
Thats the problem..the "ecm" tab isnt in bold.I cant click on it to even select a tdf file :S
Re: Tunercat Fail
http://tunercat.com/tnr_desc/ecm_sup.html#trucks ECU definition files
http://tunercat.com/tnr_desc/tnr_manual.pdf Tuners manual
This may be helpfull.
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Tunercat Fail
its been a long since i've used tunercat.
i may be thinking of some other tuning program, but IIRC, they used to have a 8D trial version you could download or you could E-mail them to get it.
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
cat, convert, definition, download, file, fs, lt1, password, registration, tdf, tuner, tunercat, tunercatcom, users, xdf
