Problem with Burn2 Programmer?
Has anyone tried to program a AT29C256-12PC with the Burn2 programmer from Moates? I have tried several times not sure what I'm
doing wrong. After the chip is burned it does not verify. This is because
the first 4 lines in the HEX Editor will all be FF not what the bin. file was
that was loaded. All the rest of the file matches. Plus it will not let me try
to burn the chip a second time. These are not OTP chips, it should re-
program.
Injected61
program.
Injected61
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Re: Problem with Burn2 Programmer?
I've got a different firmware you can load it with that can help. Give me a shout offline at craig-at-moates.net and I'll send you the link.
