Sources for laptop
Car: 5500lb Brick
Engine: Gen 1 SBC 383 Hyd Roller cam
Transmission: TH 400
Axle/Gears: 4.10 35in tires
Sources for laptop
Well the laptop died today and I need another to continue my tuning.
I was using Tunercat and Datamaster on a old Toshiba satellite 2805-S401 Win XP os& (USB to serial adapter + ALDL)
Any recommendations on Brands/Models to be on the hunt for?
Craigs list? forum members?
I was just getting the hang of this tuning on my $8d 730 TPI motor...Dang!
Thanks in advance!
So far I have found an old Dell inspiron 3500 on CL $150, has a serial port, but not sure about the other features. What do you all think?
I found a IBM Think Pad T-30 that has a DB-9 (RS232) serial port. $209
Com Do Ri Computer Tech Service.
Garden Grove, CA
(714) 944-4401
contact: Jason
Yea, I can dump the USB to serial adapter.
I do think a list should be compiled of all laptops that the board members
actually own and can verify function with the software we use to tune. Also,
if the laptop has a DB-9 (RS232) serial port.
This could be placed in the stickies or with the tuning guide for those seeking out the best computer configuration available in there area and price range.
A web search turned up some postings on computer forums as to what laptops
came with DB-9 serial ports, but I had no way to verify in each case if the information was accurate. It did help me to identify this CL posting as a possible candidate. http://orangecounty.craigslist.org/sys/1425748801.html
Thanks in advance!
Garden Grove, CA
(714) 944-4401
contact: Jason
Car: Revcon Motorhome ECM:16197427 BJKW
Engine: 502 HT W/MPFI, Thorleys, Magnaflows
Transmission: 4L80E
Axle/Gears: 3.53 + Transfercase 1.11
Re: Sources for laptop
I'm running an Acer One Netbook. They are nice because they are small, have good battery life. I'm using ScannerPro/TunerPro/Moates Burn2. Using a Microconnectors USB to serial adapter. In my case, I use it in my motorhome and have a USB to video running a live back up camera all the time. No trouble running live video and ScannerPro at the same time.
The only bad thing is the screen is a bit bright at night. I have a tinted panel I put over it, so I'm not blinded. Still waiting for Mark to get a night view or inverted colors for ScannerPro.
1Aauto
Sponsored Vendors
10-19-2016 08:50 AM
1Aauto
Sponsored Vendors
01-20-2016 01:01 PM
1Aauto
Sponsored Vendors
12-02-2015 03:53 PM
1Aauto
Sponsored Vendors
10-13-2015 03:06 PM
