INFO ON GM ECU MODE 2 AND 4. EPROM DUMP AND MESSAGE SENDING. TUNERPRO
Old 08-17-2009 | 02:48 PM
fastline's Avatar
I am working with A GM ECU through Tunerpro. I have established communications with mode 1 for diagnostic chit chat. I would like to execute an EPROM dump with mode 2. Wondering if anyone has done this with Tunerpro?
Also, I know the ECU I am working with (diesel) supports mode 4 type functions where someone can reset the initial timing. I am not sure yet how to do this as there is not much info online about it. Does anyone know what I am referring to and how execute it?
Old 08-17-2009 | 06:10 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: INFO ON GM ECU MODE 2 AND 4. EPROM DUMP AND MESSAGE SENDING. TUNERPRO
Here is some Mode 4 info.
IDK what ECM/mask you are working with but will give you some idea how it works in this application.
I don't believe the current TP can output the string lengths needed.
Most times people are using custom written code to work with this.
https://www.thirdgen.org/forums/diy-...e-4-165-a.html
gta892000
08-11-2019 12:16 PM
Jerzyperson
Carburetors
11-13-2015 02:07 AM
327IROC85
09-23-2015 01:11 AM
