EBL Flash/smoothing
Car: check
Engine: check
Transmission: check
Re: EBL Flash/smoothing
The VE table smoothing is the same in the WUD between the Classic and Flash versions. No difference. I would use the WUD for smoothing over TP.
As the VE table gets closer a lower smoothing factor works better. Lower levels of smoothing maintain the VE table as leanred in without smoothing over the corrections.
RBob.
RBob.
