LM1 and tuner cats
Old 08-02-2009 | 01:32 PM
QUICKCHICKEN's Avatar
Car: 89 Firebird
Engine: 6.0 LS
Axle/Gears: 3.70
LM1 and tuner cats
i tried a search and nothing came up plus im trying to figure out what im asking. again iv had to change tuners, first guy moved to FL, the other guy i moved and the current guy is doing great with the lil bit thes done.
my ques is how do i link my LM1 into the lap top for tuner pro/cats. my first tuner had it set up and i know which port he used but i have to make another cable and crimp an end on which is no sweat, i just dont know where to plug the line coming out of the ECM bulk head and where to plug hte other cables that go to the LM1.
Old 08-06-2009 | 12:08 PM
Ronny's Avatar
Re: LM1 and tuner cats
I have not used tunercat for quite a while. TC datalogs may be able to show WB A/F. I found if TC does not offer they can add it. Since you are datalogging with TC you need to tie into ECU I would think, so A/F is in synch with other sensor data. My aftermarket ECU is adapted to allow that input. Five chanels avalable I recall. Tie into laptop? My LM1 can log with LM1 software and reports direct to laptop using analog input during or after I complete a log. Uses a serial(LM1) to USB adapter(laptop) on LM1 cable. I think Innovate has the software to download on their site.
Old 08-07-2009 | 01:57 AM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
Try this with tunerpro https://www.thirdgen.org/forums/diy-...band-data.html
LT1Formula
10-08-2015 09:34 PM
jaridjohn
10-05-2015 08:01 AM
Quick Reply: LM1 and tuner cats
