EBL WB and port mod
Old 07-07-2009 | 07:01 AM
LB87FORMULA's Avatar
Car: 87 Pontiac Formula
Engine: 5.7L Crate Engine
Transmission: 5spd NWC
EBL WB and port mod
I am finishing the rebuild on my firebird, which includes new SLP headers, vortec heads, ZZ4 cam, LC1 Wideband and ramjet manifold.
I plan to use the EBL which I will purchase shortly. Can I run EBL with the WB alone in the stock location, and no NB sensor? This would be the easiest.
Otherwise where would be the the best locations to mount the NB and WB sensors in the SLP headers.
I did many searches, but couldn't find a definitive answer.
Thanks,
Lou
Old 07-07-2009 | 08:53 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: EBL WB and port mod
The LC-1 has two outputs, one that is pre-programmed to simulate a NB O2 sensor, so you can replace the current NB O2 sensor with the LC-1, and use this NB O2 sim output to feed into the ECM.
Old 07-07-2009 | 09:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
For locating a WB sensor it is best well down stream of the engine. There is a set of headers that have the O2 located in a single tube. While OK for a NB, it is a bad choice for a WB.
Try to have it mounted past the location where the two sides are Y'd together. And prior to the cat.
RBob.
Old 07-12-2009 | 09:02 AM
Thanks for the inputs, I'll weld a bung just pasts the y pipe as soon as I find a good location.
Rocket-Doc
11-14-2015 03:08 PM
Reid Fleming
10-10-2015 10:56 PM
Cole Curtis
Theoretical and Street Racing
10-03-2015 01:26 AM
