how to you read open loop ratio vs. coolant temps?
Car: 1989 Chevy Corvette
Engine: 383 SuperRam 10.7 AFR 195 220/229
Transmission: Fancy Smansy 87 Corvette 700r4
Axle/Gears: 3.33
I would like to lean out the whole open loop affair.
it seems the numbers get smaller ( richer?) when the engine gets warmer, now back in autoshop 101, warmer engines suppose to get a leaner mixture.
same goes with the lv8 vs.afr% change richer ( smaller number) with less loads and leans out with more load.
can someone explain?
Re: how to you read open loop ratio vs. coolant temps?
0% should get you 14.73 or whatever is stoich in your bin. Positive values will enrichen the AFR relative to stoich. Negative values will lean-out the AFR relative to stoich.
I would suggest getting to stoich as quickly as possible coolant temps around 100 F for example (assuming that your closed loop blms are in order).
I also like to zero the load influence on the target AFR in open loop. I don't see any need for load based enrichment, unless you're deliberately running very lean in open loop, for cold start/warm up emissions reasons.
Car: check
Engine: check
Transmission: check
IIRC the $6E open loop AFR (and PE) is the same as how the $8D code works. Need to take both the CTS modifier and the load modifier both into account. They are a percentage change from stoich.
Since it is the same as $8D check the Tuning Guide Book sticky, Chap 5, either '7730 or $8D section. There is a fueling calc write up that Traxion did that explains the math behind it.
RBob.
RBob.
Axle/Gears: 3.33
thanks, i made the adjustment, i'm assuming the stock entries are a percentile either positive or negative from stoich, correct?
why do stock bin have these entries? is there a reason for this?
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
ambainb
04-25-2016 09:21 PM
