disable knock sensor
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: disable knock sensor
go to Tools->ECM Swich Table and remove swich for code err 43 Knock Diagnostic
best regards
best regards
sorry, i havn't notice that You have 91 SD, i do not have def file to check that
best regards
best regards
The only way that I managed to completely eliminate the knock retard system was to cut the brown wire where it goes into the knock module. I put plugs on it so I can plug it back in if I want. This is on an '89 with MAF though, not familiar with SD so yours might be totally different.
