TunerPro RT help
Car: 84 Z28, L69
Engine: 5.0 HO
TunerPro RT help
Some background is in order. I have TunerPro RT up and running on my laptop because I use it on my Turbo Buick.
With the proper .ads and .xdf files, can it be hooked up to my 84 Z28?
If so, does anybody have the needed .ads and .xdf files for this application?
And what type of hookup do I need from the laptop to the ALDL connector?
Can this be done?
TIA
Can this be done?
TIA
Re: TunerPro RT help
I dont believe so. Here is a list of definition files from TP.
http://tunerpro.markmansur.com/downloadBinDefs.htm
Now I looked at TC. Same story. http://tunercat.com/tnr_desc/ecm_sup.html
I see 1984 Buick V6 turbo is supported! Convert !
If you want to tune you will need to swap in a supported ECU. GM 7747 and 8746 and EBL (dynamicefi.com) come to mind. Something tells me you need to repin your harness(see TurboCity, Painless Wire) to do so OR modify the ECU board called HAM see Speedtronics.net
Car: check
Engine: check
Transmission: check
Can this be done?
TIA
Can this be done?
TIA
The only downside is that most likely a 10K resistor will be required between A&B on the ALDL connector. This is required to get the CCC ECM to send data. And of course, also puts the ECM into diagnostic mode which changes how it runs the engine.
Check the Tuning Guide Book sticky for information on the CCC setups. There may be something there that will help with the required files and such.
RBob.
Car: 84 Z28, L69
Engine: 5.0 HO
Thanks guys. I was afraid the carburated 84 L69 wouldn't be supported. No big deal really. I just thought it would be another use for the TunerPro RT that I'm running on my 86 GN.
Since I'm trying to sell my 84 Z, I really don't want to have to change anything just to data log. It's almost 100% original and I'd like to keep it that way.
There are some files on moates download pages.
http://www.moates.net/fileman/index....ock%20Binaries
Didn't see any .xdf files, but that particular set of .bin files is for the '82-87 Camaros with the ZZ4 engine kit and CCC if I interpret them correctly.
Hope that helps....
Hope that helps....
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
From my understanding it just tells you what addresses it HIT, and not the data at those addresses. Also you are talking about hundreds of hits per second. I need to play with the address tracing some more to make sure this is correct.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
That would "kind of" work, but would be very convoluted and prone to error and innacuracy. For one, address hit tracing misses about 75% of actual hits (it's good for rough indication of where you're running in a table, when ALDL data isn't available for the correlation). Second, the value for an address hit is relevant only to that value in the calibration, and that doesn't necessarily reflect the value in RAM that the ECU is actually functioning off of. For instance, an address hit might indicate that a value in the spark table was requested, but that value in the table might not (read: probably doesn't) reflect the final spark that's being outputted, since the final spark takes into account spark correction, base timing setting in cal, ALDL spark, etc.
Good thinking though!
What's "address hit tracing" and how do I get it?
It was just an idea, but I guess it won't work.
