Best Bet Bin to Begin with.
Car: '91 S10 Blazer
Engine: TBI 350
Axle/Gears: 3.73 posi
Hi all - before I rip my hair out further (which at my age can leave me with nothing)....
I've got a:
~3600lb vehicle
700R4
3.73 gears
'062' Iron Vortec headed 350
Cam is 207/212@.050 .450 valve lift 112 LSA
Shorty headers w/flowmasters
TBI (from the 350 w/stock injectors)
Edelbrock square bore 4bbl intake w/adapter plate
1227747 ECM
(hopefully I've covered all the details)
Question is, what would the best BIN be to start with?
I've tried an ASDU, and ASDZ - but they both run so rich I'm spitting liquid! Not to mention bizzare idle issues.
I was thinking taking a TBI'd Camaro (etc) one, since that would be in the right area for weight, gearing etc.
Then I'll fine tune it with Tunercat. Any recommendations for a specific one? A better starting point??
I'm going nuts here, so.... help... please!
Thanks!
I've got a:
~3600lb vehicle
700R4
3.73 gears
1227747 ECM
Thanks!
Car: check
Engine: check
Transmission: check
Re: Best Bet Bin to Begin with.
Well, Camaros didn't run '7747s, so that doesn't help. I would use ASDU over ASDZ for a starter calibration. Then drop some Vortec spark advance tables into place.
After that do some VE work and get the idle to settle down. The cam isn't too radical, should idle OK. Then you should be able to drive it and adjust the rest of the VE table(s).
Will most likely need some additional injector flow. So once drive-able crowd the high load, high RPM area and see what the engine needs for fuel. Once that fuel delivery is dialed in go back to the low speed tuning (it'll be rich after you crank up the fuel delivery).
RBob.
RBob.
Car: 1983 G20 Chevy
Transmission: 4L60
I would honestly use ARHT, it has the least comprimises for emissions and fuel economy and setup more for making power.
Car: '91 S10 Blazer
Engine: TBI 350
Ok, cool - thanks both.
Using the Vortec timing tables (which I'll have to hunt down!) - what would you recommend as a starting base (mechanical) timing setting? I tried looking it up for a '97 C1500 (what the heads came from I think), but they don't list it. I've only got about 3* in there right now, and it spins over REALLY quickly while cranking (and I'm not even running a huge battery).
I really need to go harvest the Zeitronix W/B out of my turbo car and stuff it in this one for a while...
Car: check
Engine: check
Transmission: check
With that cam I would use a base timing of 4 or 6* BTDC. Be sure to also set that value in the calibration.
If you do use ARHT note that it is a stick calibration. Otherwise I too would have recommended it. Will need to clear the Stick/TCC flag along with setting up the TCC tables. IAC settings will also be different.
RBob.
RBob.
Car: '91 S10 Blazer
Engine: TBI 350
On further pondering, and checking a video I took of the engine the first time I started it.... I'm pretty damn sure I've got a massive intake leak!
It won't idle below about 950 - and last night (when I was REALLY tired I might add!) I saw the IAC count go to 0, yet it was still idling high! That should have clued me in right there. Not to mention, the ONE time I had a chance to drive it up/down the driveway it almost gave me whiplash where now it feels like a 90hp 4cyl. yet I've not really changed anything.
So... maybe the close to stock code I was using wasn't that far off??
I'm going to do a bit more testing today, then swap the (somewhat problem prone from what I'm reading) intake gaskets for a $et of the rubber/plastic compo$ite one$.
Car: '91 S10 Blazer
Engine: TBI 350
Yup - HUGE leak(s).
It's still running really rich, but I can deal with/fix that. At least it's now down to a reasonable idle. Socketed my ECM last night, so I'll slap the ROMulator on it and start tweaking.
Thanks again for the help.
Car: '91 S10 Blazer
Engine: TBI 350
Hi again...
Do you know off hand if the ASDU is/was a manual trans? I was looking at the target idle speeds, and they're all REALLY high for an automatic. I mean, I can change them, that's easy - but if all the fuel and timing curves are targeted at a manual.... I might be better off to start with something else.
Target Idle RPM Vs. Coolant Temp.
Deg C RPM
55 1800.0
65 1400.0
75 1200.0
85 1200.0
95 1000.0
100 937.5
115 800.0
120 575.0
135 450.0
2nd question... do you happen to have a copy of a timing table from a Vortec headed engine with an auto? I can't seem to track one down.
Car: check
Engine: check
Transmission: check
ASDU is for a 5.7l, 700R4, 1/2 & 3/4 ton pickups and vans, Fed emissions.
The ECU may be incorrect, this is what I see for idle speeds:
RBob.
Code:
{TempC} {RPM} 55 600 65 600 75 575 85 525 95 525 100 525 105 575 110 625 115 650
Car: '91 S10 Blazer
Engine: TBI 350
Wholey snappers... totally different!!!
Ummm, I think I'm going to hunt down a 'fresh' copy of that BIN. Looks like mine had been altered. And who knows what (well, without going over every paramater!) else has been changed too.
Any idea where I might find those timing tables?
Car: check
Engine: check
Transmission: check
There are several posted in this thread:
https://www.thirdgen.org/forums/diy-...ark-table.html
Note that the RamJet engine uses vortec heads.
RBob.
RBob.
