Any experiance with Needhams EMP-11?
I just got on the board but I have been lurking for a while. I just recently purchased a Needhams EMP-11 programmer off E-bay. It seems to be working okay as I have been able to read the two chips that I have, verfy and blank check. The problem is that I can't get a program to burn. I'm wondering if I have something set wrong on the programmer? I can't see a manufacturer on either chip so I used the setting for Intel 2732a. I used TunerCat to make chip adjustments and I'm of the understanding that from there I should be able to load and burn. Unfortunately, I have been unsuccessful to this point. I did a search on "EMP-11" but only came up with one thread. Thanks in advance.
Anders Farr
Anders Farr
Re: Any experiance with Needhams EMP-11?
I suppose a little back ground on what I'm doing would help right. I have a Jeep 4.0 that I installed a TBI from an 88 4.3. The ecm is the standard 7747. Thanks, Anders
Well looks as though I have the programing part sorted. Got my new proms in the mail today and turns out this programer is picky if you don't have it set on the correct manufacturer. Now I just have to get one done and see how it works.
Anders
Anders
Bohemian
Aftermarket Product Review
11-25-2015 09:38 PM
