IAC keep alive learn param minimum temp??
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
What is the meaning for this? It is at location 69A in my S_aujpv4 BIN. My concern arises because my car runs at ~77°C and the setpoint for this is 85.3°C in the BIN.
Car: 91 Firebird
Engine: 6.0
Re: IAC keep alive learn param minimum temp??
wow, interesting...... I need to check on this myself
Does your idle not stable at lower temps? Try lowering it and see how the car behaves....
good luck
-jason
good luck
-jason
Axle/Gears: 4.1
I was going to do that...but with all the rocket scientists around here; I like to ask first.
Car: 91 Firebird
Engine: 6.0
I'm going to try this later today once the car is back from the alignment shop.....
it suddenly has a large rpm flair at start up it didn't have before. Did the usual check for vac leaks to no avail
*joy*
-jason
*joy*
-jason
Car: 91 Firebird
Engine: 6.0
well I lowered my setting by 20* and really didn't notice anything different....
however
it was somewhat warmer out, and of course it had warmed up cause I was messing with my TF settings. I'll try again tomorrow if I get my FP replaced
-jason
however
-jason
Car: 91 Firebird
Engine: 6.0
Re: you're an adventurer...
Alright, I got the rpm startup flair down to about 1250 or so....... still annoys me
No real change that I noticed with the change in the IAC learn stuff. I didn't datalog, just going by how the car drove.
I was about to rip the FP out of it due to the car cutting out at 3k, but found a loose battery cable at the starter.... tightened that up and all was good to go.... Guess I'll do it after my intake swap
Axle/Gears: 4.1
So, lowering this temp didn't make any difference?
I have changed all my IAC & TCC codes to match the stock T-5 bin and it appeared to make a difference....seems to run much smoother.
So, other than TCC and IAC, is there some other blatantly obvious thing that would be expected to be different on a Manual vs an Auto Bin?
