S_aujpV4 TCC question
Engine: RamJet 350 running EZ-EFI 2.0
Transmission: Richmond 6-speed
Axle/Gears: 4.1
So, I edited my BIN to make the IAC values match a T-5 Bin. Things are fine. Now I've edited the TCC files also. The 4 below concern me because I really don't know if I should have left as is for S_aujpV4? Any pointers?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: S_aujpV4 TCC question
If you are using the manual trans then ignore them, they are for the torque converter lockup solenoid.
One set of addresses are for modding a stock bin to not release the lockup.
The other set is for use with the V4 bin.
Axle/Gears: 4.1
I'm using S_aujpV4 in a manual transmission car.
This evening I edited my BIN to match a stock T-5 BIN for all the values that have the word TCC in them. It's idling better.
Many thanks JP86ss
Many thanks JP86ss
