Tuning Noob success.
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
So i bought the ostrich from moates and used the AXYC bin but with the AUJP SA tables. The car is a 350 TPI 5 speed iron 193 heads lightly moded full exhaust headers edelbrock intake etc.
The VE tables should be changed to the AUJP ones right?? Because the 350 will have a different VE hill than the 305??
thanks
![blah blah](https://www.thirdgen.org/forums/images/smilies/blahblah.gif)
thanks
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1983 G20 Chevy
Transmission: 4L60
Re: Tuning Noob success.
thanks
thanks
Car: 1992 Z28
Wasn't the AUJP for 193 heads?
Car: 1983 G20 Chevy
Transmission: 4L60
AUJP was for the iron TPI heads, 083 castings. The 193s have the intake swirl vanes and a reshaped combustion chamber, this means they like about 3-6* less timing though a vast portion of the spark map. You will have too much timing around peak torque and through the upper rpms running AUJP.
This is a real good starting point for a 193 head TPI. This can probably be increased a little in a lighter, more aerodynamic, over-geared F-car.
![Name: 305TPITimingTable2.jpg
Size: 129.4 KB](https://www.thirdgen.org/forums/attachments/diy-prom/437747d1501522096-tuning-noob-success-305tpitimingtable2.jpg)
Car: 1992 Z28
Awesome!!
Ill try this out later today and let you know how it goes!
![thank you](https://www.thirdgen.org/forums/images/smilies/thanks.gif)
Car: 1992 Z28
do you have that file as an attachment?
I just hand inserted all the values and hit close and they were gone
Thanks for the help.
What is that table from?
What is the bin for the 193 heads???\
Th anks
![bs](https://www.thirdgen.org/forums/images/smilies/bs.gif)
Th anks
