Rbob I listened to your advice, but still not sure whats going on..
okay, so i i took your advice, i picked my parts and stuck with them. i read more, and did more research, started tuning my chip, its been a long road, but i think i got it now. but im not certain if its something missing in my chip that i need to input or look over. okay here is the break down of what im running; 383ci, 4l60e built (dieing), 4.56 gears on 33s, true 90# bbc injs @ 16~17 psi... i believe the bin its set at 91 or something for injs. cubic inches is set a little over a 383 more like a 390 or something.. my VE is okay to me.. lil rich but safe i would say.. no black smoke just at the upper rpms, like 5..4K. my SA is out of this world feel, especially part throttle, wot it brings it. overall im extremely happy with what ive got. my stoich is at 14.3... i tried 14.1 but it didn't like. sorta bogged for about 5 secs. 14.7 its fine too, but smells slightly rich no color @ idle. i got my sliping tranny line pressures up, and it works for now, till i swap a 80e built. as far as AE goes.... things are good now.. was a battle though with the super highrise hurricane intake which is single plane. siting on it the BBC throttle body and blades. alot of people say hey add AE.. in my case it was hey.. subtract the hell out of me.. divide.
well if anyone with expertese can chim in, that would be great; i can provide screen shots of things here in a minute.
Re: Rbob I listened to your advice, but still not sure whats going on..
ok so my fuel curve looks like this... let me know if you need to see the tables.
then i love my spark table, not extreme, but i call it conservative, with brutal part throttle. makes the heavy truck switch through lanes.
and like i said... this works for me. alot of stuff ive tried, has not. i must be doing something correct here, cause this tune, brutal kills the dyno tune i had. difference is that i have the highrise, bbc tb, and injs, with my tuning. i started to tune, because the tuner couldnt figure it out. the truck is like a jet out of hell now.. but i just need to be sure, that im on the correct track.
let me know if more info is needed.
Car: check
Engine: check
Transmission: check
Hmm, well, to me you figured out what was going on and ended up with a decent tune. Congrat's on sticking it out and ending up with the additional knowledge and experience.
You mentioned a little rich at 4K+ ("smoke just at the upper rpms, like 5..4K."). On your VE% table it is flat above 4K RPM or so. It is normal for it to taper off in VE percentage.
Once past the peak torque the VE of the engine is dropping off. However, usually the HP is still increasing which requires more fuel. What is also happening is that the injectors are firing more often. So there is more fuel being delivered as the RPM increases.
This picture of a VE table shows this tapering off once past peak torque.
RBob.
RBob.
Happy holidays! "All I want for XMAS is a 2009 ZR1"
TBI MAX. I have to ask. why are you using an xdf for a TPI? SOD_V03A TPI.xdf
RBob.
RBob.
makes sense about the way too much fuel up top. i must note.. this was one of the biggest changes i did, was to set the TPS threshold to double AE movin it from 99% to 55%. alot of people seems to have trouble with the 7427, but this is your friend for a heavy truck... truck just LOVES it. i just need to try that VE tapered.
HoosierinWA
10-07-2015 10:15 AM
