TunerPro compatible USB to Serial adapter
Car: 1986 Camaro
Engine: 355 HSR
Transmission: TH-700R4
Axle/Gears: 10 bolt 4:11 posi
I can't seem to find a compatible usb to serial adapter for TunerProRT. Does anyone use one or know of one that WILL work? I have heard a couple of name brands such as Keyspan, or IOGear. I am trying to use a laptop without a serial port and am having no luck at all. Also I see where some have used "Radio Shack" cables, but is that Radio Shack brand or Belkin or what. A list of known compatible adapters would be very helpful.
Thanks!
Thanks!
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
Re: TunerPro compatible USB to Serial adapter
I got one from moates.net and it works with my tunerpro RT and also with my Tunercat II cables.
I think Keyspan or something like that.
http://www.moates.net/product_info.p...roducts_id=129
I looked it up for you.
Bought some cheap ones first and just wasted my money.
Car: Revcon Motorhome ECM:16197427 BJKW
Engine: 502 HT W/MPFI, Thorleys, Magnaflows
Transmission: 4L80E
Axle/Gears: 3.53 + Transfercase 1.11
Try MicroConnectors. That is what I use.
