First step cam swap ?
Car: TransAM
Engine: 355SBC
Transmission: TH700R4
I want to fit a LT1 cam (Duration 230/208 Lift .450 .460) in my LO3 TBI.
What´s the first step to produce my own chip ? Which tables should be changed ? Please help me. I´ve got the tunercat software, an eprommer and the stock 88´tbi file in my computer. But I´m new with these things.
Greets Jan.
Greets Jan.
1 Post
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: First step cam swap ?
Greets Jan.
Greets Jan.
But I do know how much reaserch, timeconsuming and headache is involved by tuning the stock ECM.
I really suggest u get an EBL. Will make it alot easyer. Most people on here have burned over 100-500 chips to get it close to right or right. EBL is also a much faster calculator that use much more data to calculate and will allow better performance.
Miself have recieved this information when I whanted to get some prformance out of my LO3, I remember it was one of the moderators that has a 3.8 turbo, he wrote that he would not consider tbi without EBL. HE WAS RIGHT.
After 100 or more datalogs and enormous time reading in the tbi forum over 2 years Id did finally understand what he said. And got a EBL.
U happy with your performance chip? Expect to consider it a garbage chip once u get EBL to run your set up
Thats the cam im running with stock 187's. Jan has ported 081's on his LO3. Luky him.
