ostrich 2.0 vs. apu1
Car: no, truck
Engine: 5.7 tbi
Transmission: 4l60e
Axle/Gears: ?
i have a 95 chevy truck with the 7427 ecm that i plan on tuning myself. my question is what is the diference between the ostrich and the apu1. they are both emulators so why is the apu1 more expensive than the ostrich?
Car: 1992 camaro z28
Axle/Gears: 2.73:1
Re: ostrich 2.0 vs. apu1
The ostrich is only an emulator where the apu1 also has a chip burner built in and I believe it also has a datalogging feature built in as well so you don't need the aldu1 either.
Car: no, truck
Engine: 5.7 tbi
Transmission: 4l60e
Axle/Gears: ?
so with the ostrich and using tunerpro rt i would still need more hardware to change my stock tune?
As stated the APU1 is basically an "All in one".
I prefer the seperate idea, and it has to do with failure. Face it these are electronics and they fail for what seems like no reason sosmetimes. So If one part developes a problem, say the programmer section on the APU1, the entire deal has to go back to be serviced/repaired, where as going the seperate route, (Ostrich, ALDU1, BURN2), if one section fails, then you still have the other two parts to continue doing what you need to do.
I know there would also be times where all I want to do is datalog without emulating and to use the entire APU1 seems overkill just to datalog.
I love the idea of the APU1, I've just had experiance with other "All in one" electronics (Home stereo/theatre) where owning an all in one, means that the entire piece has to go away and are not able to listen to the radio/surround sound when the DVD player needs servicing.
The APU1 has a few adantages over the seperates idea though.
The APU1 also has the ability to add a few A/D channels to the log chain, with an addition piece (the APADC), comes with a free licence for Tuner Pro RT and is a single cable input to the laptop. Buying an Ostrich 2.0 gets you a discount on the TP RT licence though.
Car: Chevy truck
Engine: supercharged 355 tbi
Transmission: NV4500 manual
Axle/Gears: 14 bolt w/4.56 and detroit locker
hey, i have the same exact truck as you. i have tunerpro rt on my laptop, and i have a ostrich emulator on its way as well as a datalog cable, thats all you should need.
Car: no, truck
Engine: 5.7 tbi
Transmission: 4l60e
Axle/Gears: ?
it seems to me that im leaning towards the ostrich. now i have a good understanding of what both of them do. thanks for the replies!!
UltRoadWarrior9
04-28-2020 10:39 PM
