can't datalog on tunerpro RT. help.
Old 07-28-2008 | 01:35 AM
age's Avatar
age
Car: 1992 Z28 1LE
hey guys,
anyone here been successful in datalogging with Tunerpro RT? I got the setup from Moates (autoprom, real time emulation, etc), and tried datalogging today, but with no luck.
My ECM is the 1227730. I have a 92 Camaro L98.
I downloaded the .ads file from both the Tunerpro website, and an updated version from Moates website.
I am running the 6E.xdf file.
when I load the setup for datalogging, it says that the .ads and .xdf file do not match ("mismatch ADS and XDF), and it doesn't connect. I've done it with the ignition on and off, and still nothing.
am I doing something wrong here?
Old 07-28-2008 | 02:56 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: can't datalog on tunerpro RT. help.
You should run the 8D.ads file and 8D.xdf file.
/N.
Old 07-28-2008 | 09:53 AM
age's Avatar
age
Car: 1992 Z28 1LE
gta324: cool. thanks for the help. I'll download them tonight. But I'm curious, why didn't the 6E and the 1227730 .ads work? Did I do something wrong?
Old 07-28-2008 | 04:21 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
$6E is for MAF cars, yours is Speed Density (SD) and uses the $8D program.
You were using a PC to read a Mac program (sort of), apples and oranges.
get the $8D files and you'll be fine.
Check your com port settings as described in the driver installation.
On the AutoProm, Confirm the horizontal switch is towards the inside (AP mode) outside is cable only. Will log in either position, emulation only works in AP mode.
Load your ADS, select file to record (will ask you to enter a file name, not look for one).
Click connect and go.
Mark_ZZ3
05-24-2018 02:02 PM
Quzyle
10-15-2015 04:35 PM
ULTM8Z
10-02-2015 02:25 PM
Numbah-1
10-02-2015 09:27 AM
MitcherNeaf
09-24-2015 10:23 PM
