WBo2 not matching NBo2 readings.
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
Ok, So I am running the EBL classic, BBC TB, 90pph injectors, 22 PSi max w/VAFPR. While datalogging, with the EBL or my snap-on scanner, my WB would read 14.0-14.1 AFR, and the EBL displayes 128-132 BLM. Commanded AFR in Closed loop is 14.7. Is there a way to get this right, i.e., make the computer see 14.7 AFR as 128 BLM, because it is off right now. The NBo2 is reletively new, but no matter, because it was the same for the previous o2's. O, they are heated also. I think if I can get this closer to 14.7 stichio, I may even pick up some fuel mileage.
Thanks guys for any and all advice.
Car: check
Engine: check
Transmission: check
Re: WBo2 not matching NBo2 readings.
To bracket stoich set these tables:
# INT - Lean O2 (Lower)
# INT - Mean R/L
# INT - Rich O2 (Upper)
As. . .
Lean to 425 mV
Mean R/L to 450 mV
Rich to 475 mV
And the same for these values:
# INT - Idle O2 window Terms
In the tuning guide sticky under the '8063/'8746/'7747 section is a write up on fueling. This explains the use of the O2 window.
RBob.
# INT - Mean R/L
As. . .
Lean to 425 mV
Mean R/L to 450 mV
Rich to 475 mV
RBob.
Transmission: 2004R
thank you rbob, I forget about those write-ups sometimes and go right to the search. lol
Thanks again, I'll have to try it out.
Transmission: 2004R
Question: In the process of changing the o2 swing points to get the BLMs to read 128 at the commanded afr as read by the WB, will I have to change ve VE tables to get the BLM back to 128? Since I am at 14.1 AFR with a 128 BLM, (the int o2 tables were the EBL.bin tables), I am thinking I will have to lean out the VE tables some to get it to read 128 again. Is this correct?
Transmission: 2004R
I may have to cough up the dough and get a new o2. This one is swinging and all, doesn't seem lazy, but I lowered the thresholds, and raised them even. by 150 each way. And the ECM keeps displaying lean to me , the BLMS are 138 or so at cruise, steady state, and it is adding fuel. The WB is showing 14.1. Now at Idle in closed loop itis reading fine? 128 with a 14.7 +/- .1. Do you remeber the P/N for the delco 3 wire o2?
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Pretty sure it was AFS-74
The 4 wire is AFS-75.
Transmission: 2004R
Thanks for the reply JP, I was just gonna kill some time this morning and search to find it. lol. I'll try and order one from Rock auto, so my o2 swing point tuning will have to wait a few days.
1Aauto
Sponsored Vendors
09-13-2017 12:58 PM
gta892000
09-16-2015 12:37 AM
