How to connect to ALDL?
Car: 1986 Z28
Engine: 355
Axle/Gears: open 2.73's
I made a cable from one of the posts on the forum But come to find out my carbed 86 Z-28 ALDL connector only has pins on F, D, C, B and A. How do I connect the 2 wires to the ALDL? Thanks in advance for any help I can get, Mike
Car: 1986 Z28
Engine: 355
Re: How to connect to ALDL?
someone must have a carburated engine that they made a serial cable for to read from the aldl. Please any help with how to connect to the ALDL would be greatly appreciated. Thanks, Mike
Car: check
Engine: check
Transmission: check
Will need a 10K resistor between A & B on the ALDL connector. That will enable the data stream.
The data should be on pin D. I may be wrong about the pin, but give it a try.
RBob.
RBob.
Car: 1986 Z28
Engine: 355
yes that worked but data stream seemed not right. I will need to fool around with the ecm settings I think in winaldl program. Thanks Again RBob
