Disable MAT and engine hardly runs
16168625 $e6 code started with bbnt code
I need to disable MAT i keep getting low MAT error code we dont have a mat setup
runs in CPI mode and fires every drp
1 injector TBI setup
Car: Death Mobile
Engine: 666 c.i.
Re: Disable MAT and engine hardly runs
Can you hook up a 4.7K ohm resistor in place of the MAT Sensor? I don't think you can just "disable" the reading of the MAT. Using a 4.7K resistor tricks the ECM to think it's 55*F reading and the ECM will run fine with that reading (for a quick fix).
With E6 code you can disable the MAT. The switch is at address 400B bit 6.
Hey Walker how did you get it to fire every DRP. With a CPI memcal I believe its supposed to fire every third from them being on a v6.
Guys i tried to disable 400b b6 NO luck the car will not run
as for every drp ... tied pins together in the memcal then used a CPi broadcast code $e6
I don't understand 400b bit 6 is the mat select bit, it should have worked.
Are you saying that after you unchecked the bit that the car will not run, but with it check it will?
I just don't know why it would do that.
I have attached all the E6 hack information I have. Hope that will help.
You can read the BBNT one, but I don't know how much you will learn from it its very incomplete. BDKJ is the most complete.
Just a question, but why haven't you upgraded to 0D? and how much tuning have you done with that bin? I have the equivalent of what your working with in 0D if you want it.
Well I can't see where your email address would be posted so I will post the file here. This bin is from a 94 Olds Bravada CPI. I read the bin myself because I couldn't find one anywhere on the net. I think it was the only 0D CPI code used.
Also check out Demented's 0D dis here
https://www.thirdgen.org/forums/diy-...ts-time-8.html
near the bottom.
near the bottom.
Car: 1983 G20 Chevy
Transmission: 4L60
near the bottom.
near the bottom.
The .bin I cannot find is the 4cylinder automatic S10. I know they were made but I cannot find one. The stick bins lack the transmission coding.
I forget about the Astros. Those changes to the bins are mostly transmission mods right? I I'm correct on this, the CPI engines were almost exactly the same the whole time they made them.
