ARFP.BIN vs AXCN.BIN
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Re: ARFP.BIN vs AXCN.BIN
It looks like the AXCN is a updated version of the ARFP, alots of changes in the code but not so much in the "chip tables".
/N.
/N.
Hmmm.. Ok.
I think the ARFP.BIN is for the 90 vette and AXCN.BIN is for the 91..
Would be interesting to know what the difrence is, if its something that affect drivabilty.
Cheers
Cheers
Car: check
Engine: check
Transmission: check
One interesting difference is that the CCP output is inverted between the two. IOW: one BIN has the CCP solenoid active when the driver output is low, the other BIN while the driver output is high.
RBob.
RBob.
1 Post
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
They also changed the "Force Idle cell learn if CCP DC"
Maybe a prg error from GM that they fixed in -91?
I'm in the car buisness so I know how many mistakes that can be made.........
Car: check
Engine: check
Transmission: check
The driver output activates the CCP solenoid. The thing is, CCP solenoids come in both NO and NC versions. So there may have been a change in which solenoid was used. Or there was a mistake in the calibration. A mistake in the calibration would have the cannister solenoid purging when it shouldn't be. And not purging when it should be.
RBob.
RBob.
