About to buy ostrich, what hardware do i need for datalogging?
Car: 1981 Chevy Malibu, 1987 Formula 350
Engine: 229 V6, L98 TPI 350
Transmission: TH350, 700R4
Axle/Gears: 10 bolt ???, 9 bolt 3.27 posi
I'm excited to start learning about tuning hands on, just picked up a laptop today and i've been up all night reading threads and articles on this stuff. I want to buy the Moates Ostrich 2.0, as far as I understand I will need an adapter to use it with my 87 GTA (350 TPI), which one do i need?
Also, for real-time dataloging, do I just need a cable to connect to the ostrich or would it just connect directly to the laptop?
Thanks,
-Chris
Thanks,
-Chris
Car: Used to drive a camaro
Re: About to buy ostrich, what hardware do i need for datalogging?
The adapter you can use is the GP1 adapater. For the Ostrich it will have its own cable that plugs into that GP1, then a USB cord so you can connect to the laptop. After that, pay your 30 bux to support Tunerpro RT.
how bout for the dataloging part? Do I just need a cable that plugs directly to the laptop or has it got something to do with the Ostrich as well? Thanks :-)
Okay, so I'm going to get the Ostrich 2.0 as well as the G1 adapter, that should take care of the emulation side of things, what do you guys recomend for an aldl cable? I've only got 1 usb port on my laptop so the aldl cable needs to be serial if i'm not mistaken? thanks
Guys, correct me if I'm wrong but he won't need the ALDL cable with the Ostrich for datalogging correct? I only did this like 3 times last season so I don't remember but my laptop doesn'pt have serial ports and I datalog through TunerPro RT and my Ostrich 2.0
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Yes, he still needs an ALDL cable with the Ostrich. You're thinking of the AutoProm, AC.
I'd recommend the ALDU1 + CABL1 combo.
Please read through the documentation on the Moates site. http://www.moates.net/documentation.php
Car: '88 Formula, '95 Formula
Engine: LC9 , LT1
Transmission: TKX , 4L60E
Axle/Gears: 3.50 9" , 3.23 10bolt
Thanks,
-Chris
Thanks,
-Chris
It will have to be before the end of april though, as I'm closing the doors for good.
-- Joe
1Aauto
Sponsored Vendors
09-13-2017 01:58 PM
codeysabatini
11-10-2015 05:07 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
09-22-2015 09:28 PM
Saxondale
09-14-2015 07:37 AM
