O2 sensor mounting
Car: check
Engine: check
Transmission: check
Re: O2 sensor mounting
Probably not a good idea (upside down that is). Although it may last for a long time. What would kill it is if any water ran down the pipe while the sensor was hot. The water being from combustion.
If you could place a small dam in front of it to divert water, that would be enough to protect it. Maybe even make the O2 bung fitting with an extension on it. That would place a shield around the sensor tip. Kinda' like a spark plug anti-fouler.
RBob.
RBob.
ambainb
04-25-2016 09:21 PM
