91 350 TPI A/T broadcast codes differences??
1 Post
Car: 91 Formula
Engine: 350 L98 SD TPI
Axle/Gears: 10 bolt PBR 3:23 disc posi
GM has 3 different broadcast codes for the 91 350 TPI A/T which are ANJF,ANJA and AUJP. What are the differences between them if any? I have a ANJF and a AUJP that came out of 91 Z28s that had the same engine,tranny and rearend gearing. I'm wondering why GM has 3 different BC for the same setup? Thx.
Re: 91 350 TPI A/T broadcast codes differences??
So that could be the difference in ANJF versus AUJP.
OR, it could be one was for VATS versus non-VATS for a particular model.....
1 Post
Car: 91 Formula
90-91 all 3 were used but in 92 only the AUJP was used.
Has anyone read all 3 of these to see what the difference were?
If in 1992 only AUJP was used, and before that, all 3, then that indicates a change due to some issues in the older cals (most likely either spark knock sensitivity or a driveability issue at some temperature or altitude......
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Most likely they were updates for better drivability and or consumer complaints.
I know there are a couple different AUJP's also.
Best to go with the latest one you have available.
Car: 67 Firebird Convertible
Engine: LB9
Axle/Gears: 3.55
I read somewhere that a different prom was used in the cars with the 16" bigger tires and lower rear ends, and the prom was adjusted to calibrate speed.
Don't know for sure.
Sanjay
08-12-2015 03:41 PM
