Best Chip model for a 165 ECM & 88 Vette
Car: 1988 Corvette
Engine: 5.7L TPI L98
Axle/Gears: D36 2:59
Anyone out there think the ARAP chip is the best for a 88 Vette just stock not modded chips. I'd like to find a good chip to start burning with.
Car: check
Engine: check
Transmission: check
Re: Best Chip model for a 165 ECM & 88 Vette
For that app it is probably the best to start with. Your '88 should also have the aluminum heads to match.
RBob.
RBob.
Car: Death Mobile
Engine: 666 c.i.
ARAP would get my vote as well as a good starting point.
Just make sure to disable the Cold Start Injector and do some research on the ARAP as there are number of known "tweaks" such as modifying the lower Crank Pulse Width Multiplier tables to help with starting on all L98s.
Car: 1988 Corvette
Cool thanks, I just currently started using ARAP and disabled the Ninth seems like it runs very well on it. thanks again
