Bluetooth Wireless set up with AutoProm / TunerPro
Car: 86 L98 Coupe (Original Owner)
Engine: L98 TrickFlow heads & Cam, 52mm TB
Transmission: 700R4 w/shift kit
Axle/Gears: 2.59
Previously connecting TunerPro to my AutoProm with a USB through com port 4. Today I added the bluetooth piece to the AutoProm and a Dongle and BlueSoleil 1.6 to my Laptop. Turn the key to ign and the AutoProm gets power on via the ribbon cable and I search for devices with the BT on the Laptop. It "discovers" "BlueRadios" and connects it through the "Bluetooth serial port service". It shows a connect and it does this through "Bluetooth com port 6". but when I launch TunerPro I cant auto-detect the hardware. Have no security enabled in the BT. Tried to change the TunerPro to comm port 6 under the Preferences / ALDL/Emulation window, but the com port field is grayed out. Current AutoProm firmware is AutoProm USB v2.14A and Craig said this was OK. Appreciate any help in getting connected wirelessly. For you guys that got it up and working what kind of bluetooth device and software did you use and what was the com port status. Thanks
[Sold] Accel 30# injectors
hydrolic144
08-29-2015 04:14 PM
