VEMaster? Pros/Cons?
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
Re: VEMaster? Pros/Cons?
I think VeMaster it's really good for part throttle tuning.
I made a datalog and then I use VeMaster and the next time I have all BLM near 128.
BTW,Large cams and big displacement add some errors on lower rpm values.
Thanks. I am going to go do a few runs soon, and see what she does, with a wideband too to coorelate between the BLMs in TTS and what VEMaster does to the BLMs etc.
Car: superrammed V
original bin: xxxx
new saved: xxxx_vemast
use this new bin with vemaster, because it will change your ve tables directly on the bin used.
Sometimes i noted that the 1600 rpm lower VE table is not the same as the 1600 rpm in the uppper VE table. When it happens i change it manually.
Hope this hepls.
-Beppe-
When you use it, save your original bin with a different name example:
original bin: xxxx
Hope this hepls.
-Beppe-
original bin: xxxx
Hope this hepls.
-Beppe-
