Verify failed - emulating with autoprom
Need some quick help here. Although an upload tells me it is successful, I can't get it to verify. Using:
6E bin
165 ECM
Autoprom
27sf512 chip
I'm sure that it is something simple. Can someone help?
Thanks!
6E bin
165 ECM
Autoprom
27sf512 chip
Thanks!
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: Verify failed - emulating with autoprom
Is the emulation header plugged into the ECM? If so, try turning your key on (engine off), then upload and verify.
Car: '91 Chevy 1500
On mine, I have to upload and verify BEFORE plugging the Autoprom into the ECM or it will fail every time.
Transmission: T5WC
It will fail even key-on when plugged into the ECM? If so, you might want to contact Craig. That's might not be desireable (this means your incremental changes during emulatoin might be failing as well).
Car: 86 Camaro Iroc-Z
Engine: 305ci TPI
I have the same, Autoprom emulation on a 165 ecm and $6E code.
I think the only time Ive had it fail the verify is when its plugged into the ECM by the ribbon cable. I fixed it once by unpluggin it and since then ive just always unplugged it rather than figure out why. Soon I want to figure out why so I can do the incrimental changes while the car is running like Mangus mentioned.
Now, it uploads and then fails the verify step.. But im not sure if that means the info on the chip is ok or if it is bad. I am only assuming that the info on the chip is not correct.
Transmission: T5WC
[CA] 700R4 trans & parts
6998poncho
09-25-2015 02:56 PM
