Super AUJP v4?
#53
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: Super AUJP v4?
#59
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Re: Super AUJP v4?
I think I'm done with 90 hour weeks until mid January so its looking like I'll have time to finally finish the last of the docs and post it.
#61
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Super AUJP v4?
What is the deal with a SAUJP v4 bin? Can it be dowloaded "as is" and burned,then run in the car as it is?
#62
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: Super AUJP v4?
pretty much yep.
but you won't get the full benefit.
i don't remember for certain, i believe but it has the spark tables for aluminum heads. IIRC, V4 is based off V3.
so check it first and also be sure to read all the readme and pdf files.
#63
Re: Super AUJP v4?
The spark tables can be a bit aggressive so adjust them (as your currently doing) to avaoid ping/knocks.
Set the parameters like injector size, base timing, etc that are specific to your car. If its an auto trans it should run but WILL need the VE tables and spark adjusted.
Be sure to update the definition files in the "Released" thread before you make any changes to your bin.
#65
1 Post
Axle/Gears: 3:42
Re: Super AUJP v4?
no green
01-09-2016 09:22 PM
Damon
09-26-2015 04:29 PM
Dragonsys
09-25-2015 03:51 PM
