Magnus/RRob Q? Vista on laptop
Maybe it was my error but ....
I am having an issue with getting the EBL.XDF to be accepted into the latest edition of Tunerpro. The EBL.bin appears in documents and TP but the XDF that I moved from laptop to laptop was labled (i forget) by Windows-Vista last night as possibly damaged or error. I took from documents on old lappy to flash to documents on new lappy. When I chose new XDF(?) and move from doc to TP it does not appear. It appears the the newest edition of TP downloaded nicely but TP is just a border with the all the parameters are blank.
What am I doing wrong? Can Vista be the issue?
ps the old laptop the screen is damaged.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Re: Magnus/RRob Q? Vista on laptop
Who is this Magnus fellow?
The only issue that I'm aware of with TunerPro and Vista is file association. This means that you can't double click on a file (.bin, .xdf, .ads) and have it open automatically in TunerPro. You need to open them explicitly from the TunerPro UI or drag-and-drop.
Outside of that, I don't have an explanation for your error, other than a filesystem error (disk/disc corruption). How did you transfer the files? Try the transfer again, or redownload directly to the new laptop.
