88 305 tpi correct ecm and bin?
Car: 1988 Iroc-Z
Engine: 388 Stroker
Transmission: T-56 6speed
Axle/Gears: 3.45 9-bolt
my bin is AKHJ is this the correct/stock bin for 88 iroc 305tpi 5 speed? i dont think it is because i cannot find any info on the web about it, also the ecm that it is in, is an 8259 which i think is the upgrage/replacement for the 165' ecm.
Car: check
Engine: check
Transmission: check
Re: 88 305 tpi correct ecm and bin?
I can't recall what the new ECM number is for the '165. However, the AKHJ is correct for your vehicle, which does run in a '165. So it is most likely the correct ECM.
Specifics on that BCC: 5.0l TPI, 88 MY, 5 speed, Cali emssions, 3.45 rear axle ratio.
RBob.
RBob.
Sanjay
08-12-2015 03:41 PM
